I think the CoinOp Registry is a great product but have noticed many errors with some of the entries. Many have entered information that is wrong, misspelled, put info in the wrong place or entered inaccurate information. I know it's difficult to be perfect, but in order to have a valued resource, the information needs to be right. I'd like to ask you all to double check your entries and proof the information entered. As an example, under manufacturers two Caille's exist, one is spelled wrong, two AC's exist, change one so that we only have one, two Burtmeirer's exist, one is spelled wrong, etc., etc.. The same is true for some of the entries: In the Mills, we have a Diamond Front with '0' for a serial number. Really? Isn't the purpose of the Registry to have a record of serial numbers. Many of the records have the date of manufacture in the Model, those should be edited.
Let's all try a little harder getting it right, a lot of time has been invested developing this site, let's not screw it up! It is easy and possible to edit/correct your error.
