Pace Fancy Front prolbem
Postby ken b » Wed Mar 26, 2014 4:58 pm
HI, new to the site, truly enjoy it .Thanks to all that are involved.
I am working on the above, my problem is it will pay correct on
two cherry's and two cherry with lemon or bell, but on oranges and up
it pays 5 coins and the rest of the pay out are held back by
by the safety side. I have cleaned the slides , checked for
ruff spots changed spring and tension, and still have the issue.
In talking with one of better big guy dealers he suggested taking
spring off the safety slide, I did it pays as it should, thats ok
but it is not correct, would rather have it right than just working.
Would like to hear any and all suggestion's
thanks ken b
machine is a pace fancy front
ken b
Re: Pace Fancy Front prolbem
Postby mechanic » Tue Apr 01, 2014 12:35 pm
Sounds like your safety slide lockout is either not holding or is worn. See what position it's in on small pays if it looks like it moved on the larger pays then check the lockout. located behind the safety slide.
