by marsonion » Sun Mar 30, 2014 12:13 pm
OK, here's a picture of the typical Caille slide stack. The flange sticking out to the left on the top (JP) coin slide holds down the vertical, triangular-shaped projection on the lever which can be seen most clearly in the top image posted above. When the uppermost slide retracts to pay out on a JP win, this vertically-pointed, sprung lever is released to travel upwards and trip the jackpot release bolted to the inside of the front casting. On the next pull, the pointy-topped lever is cocked back down into position by the curved escalator drive bar and capped again by the top coin slide flange.
I have no idea what the bent wire part is about-- I don't recall seeing that anywhere before, and I suspect it is a home-fangled piece of music wire intended to stand in for some other missing part. I would need to see more of the entire mech in question before speculating any further.
- Attachments
- SlideStack1.jpg (61.16 KiB) Viewed 3186 times
