need help with mills hi-top slot machine
Postby puckhead » Thu Apr 24, 2014 7:55 am
ive got a working mills hi-top. it doesnt payout correctly. most of the time it doesnt pay when it should, once in a while it will pay out a few coins when it seems it shouldnt. i bought the mills owners book, and i see some parts missing, see attached pic. first, its missing the coin tube loading arm. its that a necessary part for paying out ? its also missing the operating stop release lever and release lever wire. it looks to me like that is not necessary for proper operation, but i may be wrong. also, the anticheck payout control lever tends to move to the forward position from the rearward postion, when i operate the machine. the spring is very strong, so i dont think its a weak spring. if its not the above, what should i be looking for? are there any other web forums for this type of question?
thanks
mike
puckhead
Re: need help with mills hi-top slot machine
Postby Daddyfrank7660 » Thu Apr 24, 2014 8:20 am
Hi. I'm new to a lot of this myself. Honestly I can't answer your questions, but I wanted to see if you have tried YouTube. I have found a lot of help there on many machines. Some coin-op guys up load some very good videos. That are very helpful. You may already know this but wanted to mention it to you. Hope you find your answers. Good luck.
Sinserely
Frank
Daddyfrank7660
