Hello
Can anyone tell me if the Black knob on the pull down arm is a screw fit ? Or is it a press fit ?
( The black ball you hold in your hand and pull )
Thanks in advance for any help
Sam
mechanic wrote:The handle ball is a screw on style however it is put on with a very strong type resin which makes it near impossible to get off. I have had luck heating the handle to soften the resin, but it may still crack the ball if heated to high.
