Fan problem on QT
Fan problem on QT
Postby Denny » Tue Sep 23, 2014 11:37 am
I was holding down the fan with my fingers while manually setting a payout. I did this a few times. Now the fan has a humming sound and mechanics work slow. I think I may have put too much pressure on the fan and bent something. Could it be the fan causing the problem or something else?
Denny
Re: Fan problem on QT
Postby Denny » Thu Sep 25, 2014 3:44 pm
Sprayed a little pb blaster on the fan shaft now everything is all good.
Denny
