Mills Vest Pocket
Mills Vest Pocket
Postby gamblingman » Sat Sep 27, 2014 4:04 pm
Does anyone have some detailed pics of a Vest Pocket Mech? I had one given to me, but it is missing a few parts. It's been a few years since I messed with one, and I can't seem to find any of the pics I took. Thanks in advance.
gamblingman
Re: Mills Vest Pocket
Postby SLOT DYNASTY » Sat Sep 27, 2014 5:18 pm
Here are some shots that I have in my files, of someone else's machine.
Hope these are of some help, as I cannot get to either of mine at this time.
If you need any other angles, I'm sure another member can fill in, as this is
a machine that most all collectors have at least one of.
Postby TheFatman » Sat Sep 27, 2014 5:43 pm
I have worked a few ... what I see most is an issue with the coin slide and the levers that are associated with it. let me know more on what is not doing. You can call if you need a 215-954-8327
Dave f
Postby gamblingman » Sun Sep 28, 2014 8:25 am
Thanks guys this helps a bunch. Mostly I think it is missing a few springs and a couple of shoulder bolts....so I think the majority of it is there, although it is pretty gummed up from grease as they always are. Two additional pics I could also use is more of a detailed pic of the reel spin pawl from the top, and a pic of the back side, opposite the coin slide. If I remember right, there is a slide bar at the to[p of that side that is missing, along with the guide bolt. (I may have some parts in my boxes of parts, but I need to see if I have anything to match it to) Tonight I will try to post some pics of the mech as I got it. Thanks again.
gamblingman
