Watling Blue Seal Help
Postby kepmr » Tue Oct 14, 2014 5:54 pm
Can someone help I'm not sure the purpose of these bronze parts. I cannot get the coins to go into the jackpot.
Thanks Ken
kepmr
Re: Watling Blue Seal Help
Postby mechanic » Tue Oct 14, 2014 7:15 pm
Hi kepmr The first two pics are the coin chute that feeds the J/P it looks like a part is cracked off where it is supposed to mount to the coin tube. I just finished restoring a Blue Seal like yours. I will take a few pics of the brass castings so you have something to compare. May take a day or two.
Postby kepmr » Thu Oct 16, 2014 7:00 pm
The jackpot chute has the mounting holes it was broken and someone welded it. I don't know if parts are missing, if you can post pictures that would help a lot.
Thanks Ken
kepmr
Postby mechanic » Sat Oct 18, 2014 10:28 am
Hi kepmr I found the pics of the missing part on your brass pieces. This is what it looks like I took it during the restoration I did. Hope it helps a little. Jim
Heres the other, it fits on the part with the hex nut on your picture
Postby mechanic » Sat Oct 18, 2014 3:50 pm
The jackpot feeder chute in your pics is missing the back end. I located some pics I had to show what it looks like. Jim
Postby mechanic » Sat Oct 18, 2014 3:51 pm
heres the other
Postby kepmr » Sun Oct 19, 2014 6:30 am
Thanks the pictures are a great help I can see where a piece of my chute is missing , in your pictures can you read the part number of the part I am missing. Do these parts work to make the coins go into the jackpot .
Thanks Ken
kepmr
Postby mechanic » Wed Oct 22, 2014 7:29 pm
Hi Ken The 3 lobe cam does have a part number on it but is very faint. This is common on cast iron pieces. I will look at the one I restored to see exactly how the parts interact and get back to you. Jim
Postby mechanic » Thu Oct 23, 2014 8:47 pm
Ken This is what I got. Your pic with the 7 stamping should be a long curved finger that goes beneath the small square door on the coin chute. When the cam goes 3 clicks the finger closes the small flap to let a coin go down the coin chute then opens the flap to let the next 2 coins go into the coin tube. Finding a cam is the key to making this work. I can ask a few ppl I know if they have one or maybe let me borrow one to have recast.
