Mills vest pocket
Mills vest pocket
Postby Denny » Thu Oct 16, 2014 11:04 pm
Just bought a vest pocket and it has a coin slide that is stuck half way going out I believe. I tried to correct the problem but couldn't. Any ideas how I can fix this. Everything looks to be there.
Denny
Re: Mills vest pocket
Postby Denny » Sat Oct 18, 2014 11:09 am
Denny wrote:Just bought a vest pocket and it has a coin slide that is stuck half way going out I believe. I tried to correct the problem but couldn't. Any ideas how I can fix this. Everything looks to be there.
I got the coin acceptor to come all the way out. Should I use a little bit of lube on it and are there any parts that move up or down? Also are there any pay slides on the machine? I think I see one sticking out next to the fan clock. Looks to be stuck as it never moved.
Denny
