2 coin escalator - is that normal?
Postby WikiSlots » Sat Nov 22, 2014 6:25 am
I've got a Mills 25 cent Black Cherry, but the escalator only holds 2 coins, even though the opening and glass can accommodate coins all the way across like smaller denominations. The teeth that hold more quarters are not there. After 2 coins are in the escalator, a third coin pushes one of the 2 coins and it rolls the rest of the way down the escalator to the coin chute.
Is that normal/common for higher denoms?
Dave M
WikiSlots
Re: 2 coin escalator - is that normal?
Postby atac » Sat Nov 22, 2014 6:56 am
I've heard them referred to as "quick drop" escalators. Some of the old operators did that to eliminate some of the jamming.
atac
Postby TJ » Sat Nov 22, 2014 3:08 pm
Some of the new operators do that as well know what I mean. The parts are available to restore that back to the way it should be.
TJ
Postby TheFatman » Sat Nov 22, 2014 3:55 pm
Also known as a "Roll Away"
Postby WikiSlots » Sat Nov 22, 2014 9:12 pm
Thank you to all of you. You all are awesome.
WikiSlots
