mills reel help
mills reel help
Postby pj waelti » Mon Dec 01, 2014 5:29 pm
I need someone smarter than me for this one, I think I am in the right place. I have a mills payout disc numbered cc17-1b. Can someone tell me the order of fruits on the reel strips? Or point me somewhere to find out.. Thanks alot everyone, PJ Waelti
pj waelti
Re: mills reel help
Postby oldslotman » Mon Dec 01, 2014 6:26 pm
I think this is right but not sure. ORANGE, WATERMELON, PLUM, CHERRY, PLUM, ORANGE, LEMON WITH A 7, BELL, ORANGE, CHERRY, BAR, PLUM, ORANGE, PLUM, ORANGE, PLUM, CHERRY, PLUM, BAR, PLUM. Disc code should be EJ1-B
Re: mills reel help
Postby pj waelti » Mon Dec 01, 2014 7:09 pm
Thanks, but the disc code on mine is ej-1a, not ej-1b.
are they the same? Thanks again.. PJ
pj waelti
Re: mills reel help
Postby oldslotman » Mon Dec 01, 2014 8:02 pm
Most likely different. I have the symbols for ej1 but not ej1-a
Re: mills reel help
Postby gsx11r » Thu Dec 04, 2014 8:59 am
Hello
Do you can post a photo of your "complet" payout disc numbered cc17-1b ??
That will be more easy for give you the right order , or tell if it s the same as the ej-1b !
Stephane
gsx11r
Re: mills reel help
Postby oldslotman » Thu Dec 04, 2014 10:22 am
gsx11r wrote:Hello
Stephane
I cannot post a photo because I no longer have the machine. Are you looking for the whole set of reel strips or just the first reel strip.
Re: mills reel help
Postby gsx11r » Thu Dec 04, 2014 1:16 pm
oopss , sorry oldslotman , the question was for PJ Waelti ! :oops:
If PJ have a picture of the payout disk , we can decode the symbol and check wit the EJ1-a ,Ej1-a and other !!
SO SO SORRY for my poor english !!! :oops: :oops:
Stephane
gsx11r
Re: mills reel help
Postby pj waelti » Thu Dec 04, 2014 2:18 pm
Sorry for the delay getting back to you. The first disc is definetly different from the a to the b version. The first part of the reel strip is the same all the way to the bar line. After that they differ alot. I solved the problem by modifying mine into the same configuration as the b disc.Minor welding of the disc required.I know a purist would shoot me but the machine seems to be an assortment of parts already,,at least the reel portion that is..The rest looks original mills parts. Thanks again, PJ
pj waelti
Re: mills reel help
Postby pj waelti » Thu Dec 04, 2014 2:22 pm
Forgot to say also I modified it so the discs were the same as the other working 777 machine I have access to. Need to put it back together now to find out. Probably this weekend..
pj waelti
