A tale of Two Clocks
Postby thepennyarcade » Tue Dec 16, 2014 2:53 pm
Hi Forum
Today when cycling my Mills HT the reels slowed down and stopped
When I gave the clock spring a little wiggle the cycle finished
I removed the clock and found the main clock gear had a few gear teeth worn down
When I went to my spare clocks I found I had two different clock arm versions
Anybody know which style goes on a High Top
The clock on the left has a wide push bar on the clock arm and the one on the right has a smaller push section and a "L" bracket to stop the arm movement.
John
thepennyarcade
Re: A tale of Two Clocks
Postby oldslotman » Tue Dec 16, 2014 3:24 pm
the clock on the left looks like a clock for a Pace slot machine.
Postby mechanic » Wed Dec 17, 2014 7:56 pm
The clock on the left is a Pace clock. The clock on the right is a Mills with a limiter bar on top so the arm does not go back too far. The clock on the right goes to the HiTop. Also the wide pushback plate is how you tell a Pace from a Mills in most case. The fan blade being the other usually the wide rounded end style
