pj waelti wrote:Cleaning a friends caille cadet. The machine hasn't worked in 30 years.. Before I take the clock apart and wreck something, I better check here for some advice on what to look for.Or how to clean and relube the hyraulic clock. Thanks for any advice. PJ
pj waelti wrote:Thanks for the input.. The cylinder has some fluid in it. Pretty nasty color though. Do I drain the the old stuff and refill with new? or just add to the old stuff that is in there? Also there is a slight resistance when turning the lever. Thanks. PJ
pj waelti wrote:added fluid and bled air out. Seems to work good. It does have fluid seeping up the crank seal on top. So what is the cure for this? Thanks. PJ
pj waelti wrote:The repair looks straight forward, nothing a car repair guy like me could'nt fix. What would you use for a seal? An o-ring? Also refresh my memory on what I bought from you. Remember I'm old and can't remember crap..HA PJ
