Golden Falls, real or reproduction?
Postby loveoldslots » Sat Oct 17, 2015 12:28 pm
See picture below. I am looking at a Golden Falls machine, but it has the ball type handle and not the lever/sword type. All the mills machines of Golden falls and those years DO NOT have the ball type. The machine looks pristine on the outside. But, if this were a reproduction, I cant see why it would be the ball type handle as they were made to look old which meant the sword/lever...Which supports that this machine may have been used in a casino. The is a sign in the slug window stating to noify addendant for jackpots. Are there any other EASILY identifiable clues to be able to tell the reproduction from the real Golden Falls? A serial number? something where it can be easily determined maybe by just opening the back and seen without taking it apart?
Last edited by loveoldslots on Sat Oct 17, 2015 10:28 pm, edited 3 times in total.
loveoldslots
Re: Golden Falls, real or reproduction?
Postby loveoldslots » Sat Oct 17, 2015 3:08 pm
this is a picture of the machine noted above
real of reproduction?
loveoldslots
Postby oldslotman » Mon Oct 19, 2015 11:59 am
Wood cabinet appears to be a replacement and it does appear to have a false jackpot in it since it says that jackpot will be hand paid. Without seeing the insides I would say it is most likely a reproduction of some kind.
Postby TheFatman » Mon Oct 19, 2015 12:42 pm
Might be a Black Cherry with repro columns or a Royal Bell with the fake JP and an escalator that is a dummy.
dave F
