GEM:
I would definitely stay away from this machine, unless you are an advanced collector, that wants a project to play with,
and it is 'dirt-cheap'. This very well could be a mish-mosh of unmatching parts. Although it appears to be a Jennings
"Automatic Counter Vender", aka "Mints of Quality", it also has shoddy signs of an operator revamp, but not the type
that was revamped with a Jackpot front. What we have here, is a weird configuration, that I have never seen before.
First of all, as stated above, the mint rolls in the front casting, are just view windows, and do not vend. The Mint rolls
were acquired from a side vender, which is missing. This particular model, came with two styles of coin-view window.
A small square, or the round. Both styles can be seen in the photos below, which is how these models left the factory.
You will also notice, that someone has ground all of the lettering out of the front casting, all around the deferred-pay
window. That lower casting, around the payout cup, is also a design that I have never seen before, and looks nothing like
a design that any of the more common revampers used. Jennings did have a casting design they used on several models,
but this model usually just had the wood panel, as shown below. The mechanism may also be missing the deferred-pay
feature, or even be a standard mechanism that never had the feature.
So, if you are fixed on getting an example of this particular Jennings model, look elsewhere, as they are available from
time-to-time, but just make sure it is complete, and has all the features, as shown below. If you find another one, and
have questions, please ask us, as that is what we are here for. There are collectors on this Forum that specialize in most
all manufacturers, and models.
Good luck, Bill
- Jennings 5c 'Automatic Counter Vender' w-Side Vender 1927 (rest)1.jpg (25.66 KiB) Viewed 4910 times
