Hi Forum
Does anyone know if VPs can take tokens?
I have two machines and neither one will allow the coin slide to seat all the way in
Is there a special way to modify the coin entry mechanism?
Thanks for your help
This is a great forum
John
SLOT DYNASTY wrote:You're right on all counts Monte, but cutting off a section of only one blade, will make for a wobbly, and
noisy sounding fan, which in turn, would send a player a bad sign. Most all fan speeds were changed by
simply bending the two ends of the blade equally, which will make for a quieter spin. The tighter the bend,
the faster the clock will operate. On the other hand, if you have seen many blades cut on only one side,
like the one shown, then you know more about it than I.
MONTI wrote:SLOT DYNASTY wrote:You're right on all counts Monte, but cutting off a section of only one blade, will make for a wobbly, and
You are correct Bill about the cutting on just one side causing issues as I have never seen that and I should have clarified that point as that was his original question. All the ones I have seen and modified for the house in the 60's were either cut on both ends equally or bent as you say in varying amounts or the "butterfly" removed all together!
As for me knowing more than you My Friend, that I seriously doubt as your research on all things coin operated is on the cutting edge!
I mean really, who do I contact when I have a question, right? LOL
