Mills black cherry legit or not ?
Postby jsin » Fri Nov 25, 2016 11:53 am
Any help to confirm authenticity as a real Mills black cherry .. thanks
jsin
Re: Mills black cherry legit or not ?
Postby oldslotman » Fri Nov 25, 2016 12:39 pm
Looks legit except for the timing lever which was used on later model high tops. It should look like the one in the picture. It is the part that is moved by the clock. Someone might have changed it out to make timing the mech easier. Or it may have been a later model that was made using the newer part.
Postby JHSS-1944 » Fri Nov 25, 2016 3:43 pm
I agree with oldslotman, so far looks correct ,except that part. it's not a reproduction machine , if that's what you were afraid of. correct factory colors (2 versions only, I have the other late paint colors). more photos might be needed ,but looks o.k. right now. added plus the cash box lock door.
Postby jsin » Fri Nov 25, 2016 4:30 pm
To all that replied , thank you for sharing a bit of your knowledge and insight with me. I did make the purchase.
jsin
Postby oldslotman » Fri Nov 25, 2016 5:34 pm
jsin wrote:To all that replied , thank you for sharing a bit of your knowledge and insight with me. I did make the purchase.
Enjoy your machine. =D>
Postby JHSS-1944 » Sat Nov 26, 2016 12:14 am
My timing lever is the same as the one you just bought. ser.# on mine is 541369. what is yours ?
note mine in the other factory colors to match the jewel bells. all 3 hidden away since 1951 in Boston till a few years ago.
Postby jsin » Sat Nov 26, 2016 1:22 pm
Looking good ..all three complement each other nicely. Number on mine is 540037.
jsin
Postby JHSS-1944 » Sat Nov 26, 2016 10:07 pm
Thank you sir !!! thought yours was older than mine & it is.
