Mills Dice help
Mills Dice help
Postby PA23 » Sat Jan 27, 2007 7:53 pm
I've completly rebuild the mech in my Mills Dice. It seems to work well so far, although it took a little bit to get the coin head "feelers" adjusted just right.
My problem stems from when the machine is put into the case, if I understand correctly its the interaction of the spring loaded lever in conjunction with the main lever (on a normal slot I'd say the pork chop) and the post on the arm going to the coin head.
What happens is either nothing engages or if I pull the machine out slightly it always engages. How do you go about adjusting this? Of course visibility into this spot with the machine together is next to nil.
TIA..
PA23
