Recently purchased Skill Stop NOT working anymore, HELP!
Postby Coppola0218 » Thu Sep 14, 2017 7:46 pm
I just recently purchased this Skill Stop Machine from a Yard Sale, I had tested it before I made the decision to purchase it and it worked absolutely fine. After taking it home and plugging it in to use it, The panel lights up but when I insert a token, the token just spits out onto the coin tray.
I have attempted to reset it through the PSU, but to no avail. I CAN upload pictures of the internal components of the machine if need be for troubleshooting, But for now here is a picture of the slot machine in hopes that someone can actually identify the machine. A google search and even reverse image searching turned up nothing. Hoping I can have some luck on this forum.
-Coppola
D-Zone Skill Stop
Coppola0218
Re: Recently purchased Skill Stop NOT working anymore, HELP!
Postby Coppola0218 » Fri Sep 15, 2017 7:41 am
I managed to take some pictures of the internals of the cabinet, Hopefully I can get someone to help me through in getting this to actually work as intended.
Coppola0218
Postby marsonion » Fri Sep 15, 2017 11:21 am
Hello-- I think the reason you're not getting any response is because there isn't much expertise nor interest in electronic or even electromechanical devices to be found here; these collectors are mostly after vintage, mechanical coin-op. I think you'd have a lot better luck by bringing your questions to (for instance) this forum instead:
http://www.pachitalk.com/forums/forumdi ... 6092f90b27
I hope you'll find the help you need regardless.
Postby Coppola0218 » Fri Sep 15, 2017 11:51 am
Thank-You,I wasn't exactly sure where to turn to for this issue. I am very glad that you pointed me in a direction that could potentially help me in my dilemma. :-D
Coppola0218
