What is your favorite slot machine and why?
Postby Dave » Tue Nov 02, 2004 9:42 pm
OK, so let's start a discussion on what slot machine is your favorite machine.
For the sake of the discussion, let's remove price and rarity from the equation.
Assume all machines cost $1,000 and are readily available.
Given these parameters, what is your favorite machine and why?
My vote is for the Mills Dice
Postby Dave » Wed Nov 10, 2004 4:14 pm
OK, so I will start off with answering my own question :P
Without question, my vote goes for the Mills Dice. Why, because of the pure mechanical wizardy done to make this thing work.
The fact that you can place 3 bets at a time and it can remember up to 6 points (4, 5, 6, 8, 9, 10) over multiple throws of the dice is quite an achievement for a machine that was made in the 1930s and uses no electricity.
If you go look at articles you will see one about the Mills Dice (including a picture of the mechanism).
You can also get more information (including a vidoe of one working) by going to the online version of "Coin Op on CD". It is at http://www.IBuyOldSlots.com/COCD
