Ginger Trade Stimulator
Postby capt7310 » Wed Feb 12, 2020 12:21 pm
Hello, just purchased this Ginger cigarette from a person who had it lying around in there basement. They took off the old reel strips and gave me paper strips that were made so you could remember the position of the strips to the reels when you put the new strips back onto the reels. I cannot decipher the pattern or anything wonder if someone can. On the reels themselves they put a pattern of numbers which made it even more confusing. Any help thanks
capt7310
Re: Ginger Trade Stimulator
Postby radiorich123 » Wed Feb 12, 2020 4:46 pm
From the photos looks like you will have a big problem lining the correct umbels up. Good luck!
Postby tsparts4u » Thu Feb 13, 2020 7:58 am
Hi,
I don't know if you have found a solution to your problem, or not, but I have some thoughts on your dilemma.
My first question would be.......are the reels marked with numbers from 1-10?
If yes......are there 20 symbols on the new reel strips?
If yes.......only 10 symbols on each reel strip will ever come on the pay line, so you will use the EVEN numbered symbols as the pay symbols.
Starting from the top of the new reel strip #2,4,6,8,10,12,14,16,18,and 20 are the symbols to use.
The marking on the reel that is marked as #1 should be the second symbol on the strip, The number 10 on the reel would actually be the very last symbol on the new strip. Get the idea? Be sure that the new reel strip marked as #1 goes on the reel to the left as you look at the front of the machine.
I hope this is of some help to you. (That is assuming that this is what the previous owner had in mind as he marked the reels with the numbers shown).
Regards,
Jerry (tsparts4u)
tsparts4u
Postby capt7310 » Fri Feb 14, 2020 6:13 am
Hi Jerry, thanks for the info and I will try it out.
capt7310
