Mills Proto Type ?
Mills Proto Type ?
Postby capt7310 » Wed Nov 18, 2020 7:22 am
Just bought this Mills 10 cent machine pretty much all original but the bottom casting looks like a skyscraper and the top casting is a Operator Bell/Poinsettia. The strange thing is the award card belongs where it is on the machine and both casting are a perfect fit and everything operates as it should. I've never seen anything like this just reaching out to see if anyone has ever seen this type. The number on the top casting (see pic) and there's another one is MVO 2025. Thanks
capt7310
Re: Mills Proto Type ?
Postby nvmos2 » Wed Nov 18, 2020 12:11 pm
How does this theory sound:
Not a Prototype, but a revamp.
The top casting looks like an Operator Bell Bullsye, c 1927, near the end of the line for slots without jackpots.
Mills introduced the Skyscraper c1932.
When many of the older machines without JPs were being revamped, Mills was known to revamp their own machines.
Perhaps they revamped one of their Bullseye machines with a modified Skyscraper casting to add the JP front.
Postby capt7310 » Wed Nov 18, 2020 3:14 pm
Nvmos, your theory sounds like it's right on... thanks
capt7310
Postby mechanic » Wed Nov 18, 2020 7:11 pm
LOOKING AT BOTH FRONT AND BACK OF THE AWARD CARD AREA IT HAS TO BE A REVAMP BUT WHOSE ???? ANY CASTING NUMBERS ON THE LOWER??? MILLS WOULD HAVE PUT THEIR PART NUMBERS ON THE LOWER IF THEY DID IT.
Postby capt7310 » Wed Nov 18, 2020 7:21 pm
The top casting has MLB316and the bottom casting has MLB5206
capt7310
Postby mechanic » Wed Nov 18, 2020 7:25 pm
THOSE ARE LEGIT NUMBERS BUT NEVER SAW THE COMBO YOU HAVE WITH THE WEIRD AWARD CARD AREA. NEED TO GIVE A CALL OUT TO MONTI !!!!
Postby capt7310 » Mon Nov 23, 2020 4:08 pm
Thanks for the input and after exhausting all research to find this machine I decided to recondition it and add to the collection. Just wanted to share. Happy Holidays to all....
capt7310
