Help in Identifying Gum Machine
Postby Michael1 » Mon Jan 19, 2009 7:50 pm
Found this at the flea market about 15 years ago but didn't get around to restoring it until last year. Have exhausted all the local 'talent' for an approximate date/name but it measures about 18" tall and about 7" square at the cast iron base. Middle column rotates in four positions and when a nickel is deposited, the top rod is pressed to dispense a package of gum. Sheet metal was sandblasted and repainted with Krylon Flat White, then buffed to approximate the porcelain-coated base and top. Thanks for any assistance you may be able to provide!
Michael1
Northwestern Choice Package Vendor
Postby HSaidman » Mon Jan 19, 2009 8:49 pm
Your machine is a Northwestern Choice Package gum vendor. Circa 1917. Hope you did not remove any of the decals on it. Machine is somewhat rare.
HSaidman
Northwestern Gum Machine
Postby radiorich123 » Tue Jan 20, 2009 4:56 pm
HI
Your machine should bring about 500.00 or so if its complete.Its a good one.
Rich Bednarcik
