Any info on this machine appreciated
Postby Keather » Sat Feb 20, 2021 5:12 pm
Hi,
Just picked up this machine.
Any idea on age?
Are the painted sides original?
When I took apart to clean....found these 10 tokens behind the faceplate. Ones marked 1914
Keather
Re: Any info on this machine appreciated
Postby atac » Sat Feb 20, 2021 7:07 pm
The ribbon on the bottom casting says 1922. My guess would be 1923. The castings are aluminum--they would be cast iron if earlier and the glass was rounded not flat. And it's pre-jackpot which was around 1928. So there's the range--about 1923-24. I doubt the paint is original as they were usually just finished wood on the sides.
atac
