Coin In Escalator Jumps Back
Postby jbeck200 » Tue Apr 14, 2009 8:39 pm
I have a Mills Melon Ball dime machine. The coin moves forward in the escalator as the arm is pulled. When the arm is released the coin moves back to the original position, the machines cycles and another pull without a new coin is allowed. If I hold the arm in the down position for a couple of seconds, then the coin remains forward.
Any suggestions?
jbeck200
Melon Bell
Postby watlingboy » Wed Apr 15, 2009 10:41 am
Sounds like the advance bar is not being pulled far enough. If you move the advance bar by hand will the coin move to the next position? The bar you need to move is the one on top of the coins. That is the slide which moves the coins across. If the coins move when manually advanced then you have to bend the part the mech is pulling down. You need to bend it up to get movement on the advance bar. Be carefully when bending it up as that is a tempered part and bending it too far or too often will make it crack. A crescent wrench will work for bending it.
Hope this helps.
Coin Jumps back
Postby jbeck200 » Thu Apr 16, 2009 9:19 pm
Thanks waitlingboy, You have got me on the right track. I see the connection between these 2 parts and I should be able to work it out.
jbeck200
Postby Dave » Fri Apr 17, 2009 2:10 pm
I would bet if you cleaned the escalator it will start working.
Sounds to me like it is all gummed up with old grease.
Coin Jumps back
Postby jbeck200 » Sun Apr 26, 2009 2:21 pm
Thank you for your suggestions. I am a novice so I appreciate the help. The escalator worked out of the machine so I thought it was the draw arm distance. That didn't work. I then soaked the escalator with a petroleum liquid and with paper towels and q-tips, I removed every bit of grease, dirt, grime. I especially cleaned the coin path by pulling the coin retractor panels upper and lower for access. I reassembled the machine and it works.
Thanks.
jbeck200
