Listing Deleted
Listing Deleted
Postby dsc5 » Fri Aug 27, 2021 11:11 pm
Listing Deleted
dsc5
Re: Mills Copper clip in Escalator and on Clock mount ???
Postby atac » Sat Aug 28, 2021 6:12 am
They are both spring "guides" - the escalator one is officially named the "coin advance bar clip" (basically a retainer for the coin advance bar) and the lower one does the same thing for the slide release lever. I couldn't find the official name for it.
atac
Postby RameGoom » Sat Aug 28, 2021 9:08 pm
The material is actually Beryllium Copper, and alloy, that is a spring material. It's much harder than copper, and is used to hold the coin in a certain position in the escalator. Probably to keep it from dropping too soon. It maintains its spring tension and shape.
Hope that makes sense.
Postby dsc5 » Fri Sep 17, 2021 6:29 pm
Thanks Gents, I really appreciate it !!!....mystery solved
dsc5
