Mills or Sega?
Fri Mar 11, 2022 11:32 am
by wildman
Attached are some pictures of my slot machine.
I have been told, it really is a Sega.
It takes dimes, and also penny's.
It is really obvious that the pay-out card is not the original.
The jackpot looks almost full; not sure if it does not payout, will the slot jamb?
I am just a very early beginner, so do not know a lot about slot operation/
Re: Mills or Sega?
Fri Mar 11, 2022 1:18 pm
by Gaz83519
Looks like a Sega. The giveaways are the reel glass, & the top casting is squarer around the escalator window. Also, the trim around the payout tray should be different to a Mills.
Check the part numbers on the mech, if they start with SG, it's a Sega mech.
Re: Mills or Sega?
Fri Mar 11, 2022 1:37 pm
by wildman
Thanks.
I do not see SG from looking from the back. I haven't pulled it out of the case yet. I see some numbers, but not SG.
Do you know what would happen if the payout gets full, and does'nt empty?
Re: Mills or Sega?
Fri Mar 11, 2022 2:22 pm
by Gaz83519
When the jackpot gets full, the coins should overflow into the cashbook.
Re: Mills or Sega?
Fri Mar 11, 2022 2:33 pm
by wildman
Okay, thanks
I wonder where I can get a better looking pay-out card? The one on it now is some type of "foil" looking; probably a stick on, and wrinkled.
It is probably the right one for the reals that are in it; but if it is a Sega, it probably should be a 777 card. I really don't want to change the reel emblems
Re: Mills or Sega?
Fri Mar 11, 2022 2:40 pm
by wallruss001
If it plays really smooth chances are it is a SEGA. I picked up a SEGA Bell long ago, the glass is identical to your hightop. My daughter has it and loves it. I just picked up a SEGA Mad Money, takes nickels, although it's an English 1Pence. It has a token dispenser for 3 Star Jackpot. Again, super smooth operation.
Re: Mills or Sega?
Fri Mar 11, 2022 5:06 pm
by wildman
Mine takes a little effort to pull the handle. I don't know if there is a way to make it smoother. Looks like a different spring on the handle, might help. The one that is there looks to heavy; am attaching a picture
