What does a NTF Serial Number mean?
Postby dd28 » Sun Nov 05, 2023 4:34 pm
Hi, I recently purchased a slot that says the serial number is "NTF". Does anybody know what that means? It's lot 3453 on Morphy Auctions if you need to see it.
dd28
Re: What does a NTF Serial Number mean?
Postby shortrackskater » Mon Nov 06, 2023 3:49 pm
Just a "random slot" ???
Is there brand? Mills? Jennings? etc? Please post a photo of the machine. The more educated members may know what that prefix means.
shortrackskater
Postby dd28 » Mon Nov 06, 2023 4:46 pm
It’s a mill high top. Image isn’t uploading it’s lot 3453 on Morphy Auctions for photos.
dd28
Postby shortrackskater » Mon Nov 06, 2023 5:19 pm
You could post a screen shot of the machine, but this should help. Is it NTF or NFT? I think NFT designates some kind of token machine.
shortrackskater
Postby dd28 » Tue Nov 07, 2023 8:57 am
It is a 5 cent machine not a token machine and it says NTF not NFT. Here’s the link so you can see photos and description:
https://auctions.morphyauctions.com/Lot ... yid=586429
dd28
Postby oldpinguy » Tue Nov 07, 2023 9:09 am
Have you asked Morphy what it means?
My guess would be it means “No Text Found”
oldpinguy
Postby 63mini » Tue Nov 07, 2023 9:48 am
Your best bet is to just ask Morphy's what it means. There could be a lot of definitions. With that said. That machine will have a serial number stamped into the center (back) of the base. Also, there should (might still be) a paper tag with the serial number inside the case. I have attached a photo from the listing showing the serial number location. I am able to see part of a "22". Unable to see the rest.
63mini
