Home Made Creation?
Home Made Creation?
Postby 63mini » Sat Jan 13, 2024 7:33 am
I purchased a few machines from an older lady the other day. When I was there, she asked me about the machine shown in the attached picture and asked a value of it. I told her it looks like a homemade creation (fairly nicely done) I believe someone used a Jennings baseball as a base donor machine #-o . Unfortunately, the key with the machine did not open the lower door to access the mech. I told her she should ask around $300-400 dollars for it? Does that seem reasonable?
63mini
Re: Home Made Creation?
Postby radiorich123 » Sat Jan 13, 2024 7:45 am
That is a rare machine and if working good probably worth around $1000 dollars or so
Postby altort » Sat Jan 13, 2024 9:42 am
That is a Jennings Electro Vender not often seen but not a lot of value, the last one sold at auction for $600.00 in 2019 on the low end one sold for $2500 in 2017 on the high end, the one you have pictured is missing the base, I only seen them with the base,
Postby mechanic » Sat Jan 13, 2024 1:15 pm
JENNINGS ELECTRO VENDER AMONG THE FIRST ELECTRIFIED SLOT MACHINES. STANDS BEEN REMOVED AND SOMEONE PUT THAT BOX ON THE FRONT FOR WHATEVER REASON ??? NOT ORIGINAL.
Postby 63mini » Sat Jan 13, 2024 1:32 pm
Thanks for the replies! I now have a direction to give her as she is just trying to deal with the estate of her 96-year-old father and is a bit overwhelmed. The box on the front is an add-on and was from another Jennings as there is a ODJ tag on it. Also, I guess I learned something as I have never personal seen one of these.
63mini
