dice trade stimulator
Re: dice trade stimulator
Postby altort » Sun Mar 31, 2013 4:15 pm
Thanks for the pictures and info, is the anti cheat only on some models, not all have them as mine also does not have one, still have not seen one with the same play card as mine but have not seen most of the others as well, but the cabinet is definitely like QUALITY SUPPLY HORSES.
Are the cards reproduced?
Postby altort » Sun Mar 31, 2013 4:24 pm
Thanks Bill, I should have read first and would have had my answer, are the cards you have with the circular tilt hole and are the dice also available to match the card?
Al
Postby SLOT DYNASTY » Sun Mar 31, 2013 6:42 pm
altort wrote:Thanks Bill, I should have read first and would have had my answer, are the cards you have with the circular tilt hole and are the dice also available to match the card?
Al
Hi Al:
I just sent you an e-mail, to send for my catalog, but forgot to tell you, that I do not have a supply of dice for sale.
I only have ones that I have collected to use in my own machines. The correct size and coloration, are not very easy to find at times, and I WILL NOT put cheap aftermarket dice in any
of my machines, as it cheapens the entire machine. One example, are those poorly made Poker Dice, that I see being installed in machines alot. The standard size of spot dice for most
dice games, are 1/2", as is what is used in the Quality Supply models shown above.
Return to E-Bay
