castlefront fishmouth
Postby rosstfr » Fri May 17, 2013 9:02 pm
Ebay listing 111073482952. Wondering if anyone can comment on this machine being an original and correct US machine. The seller would not confirm that it takes 50cents. I am concerned that about the coinage, and the escalator looks different than what I have seen in my limited experience - shouldn't there be two sets of teeth pushing the coins along...
thanks!
-Ross
rosstfr
Re: castlefront fishmouth
Postby oldslotman » Fri May 17, 2013 9:18 pm
Only the upper set of teeth move the coins along. The bottom set does not move.
Postby oldslotman » Fri May 17, 2013 9:23 pm
It appears that it does not have a 50 cent jackpot. Check to see if it has a serial number.
Postby Jackpot » Fri May 17, 2013 10:41 pm
I see both sets of notches on the escalator (advance bars) and the ware marks on the escalator also look right for 50 cent coins. I don't see the larger folded jackpot door for fifty cent coins in the jackpot window. The castings should be wider then a small coin machine, and also the whole jackpot assembly is deeper for 50 cent coins then a small coin jackpot is. but this takes a tape and some measurements to determine if it's right or not. You can tell the difference if you seen both jackpots at one time, it is really noticeable.
jackpot
I Buy-sell-trade coin op's. I also have some later model slot parts. There are piles of manuals at:
http://coinslots.com/page21.html
Jackpot
Return to E-Bay
