What do you remove from your machines?
Re: What do you remove from your machines?
Postby flipper77 » Mon Feb 23, 2015 7:40 am
Definitely agree with the consensus - if factory installed, definitely should remain. I also get a thrill if the token detect parts are all there and function. Neat part of slot history. I searched long and hard for a fully original War Eagle with side vender that had all of the token parts that deflect coins/tokens to coin box, don't pay on token play, all of the original factory options. Marvelous mechanical engineering to have all of this functionality after all of these years.
I do make one exception on Mills - those darn second coin detect/lock on the escalator can be a real headache and nearly certain jam if played over time. Here is picture of one installed on my Futurity. If they work fine, I leave them on. If they jam a few times, the mechanism comes off and goes in the coin box. Little issue with nickel/quarter but penny/dime can be problematic and those are the denominations that you really need the second coin lockout. Typically find bugs and I remove them as the operators put these cheat devices on after it left the factory. Here is one on a Castle Front I just bought.
Flip
flipper77
Postby TJ » Tue Feb 24, 2015 3:24 pm
I have a Roman head with the same bug it has the gold award but you can never get the three symbols to come up, the lever that bumps the gold award dispensing lever is also gone. Some operator didn't want to ever pay that award. T.J.
TJ
