Bucky wrote:PS do you have any pictures available (or can you take any) of the machine mechanics from the front and rear and sides, especially the lower end from the front and rear? Just trying to identify if I have any missing parts or springs.
Bucky wrote:The damper I found is a hydraulic rotary damper. There are different versions available, with damping in one direction (lh or rh ) or both directions equally. Also, there are versions where the damping is adjustable or fixed at a fixed level. My version is an adjustable one direction version, where the opposite direction is a non-adjustable minimal damping level. There is plenty of industry where I live, so it was just a matter of searching the web, and a 20 minute drive to pick up the in stock item. 8) more details once I actually get it working...
Bucky wrote:
Acecontrols.com.
I don't know who the usual suspects are, as I am new to all this. But I will have less than 100 into the replacement. Minus my time, of course.
If the rivets come out easy, I'll have a pic of what's underneath the mohawk tomorrow.
Bucky wrote:Well, the mohawk is off. No creme color paint. It was a pain too, as the forward "rivet" is really a hardened spiral pin, that I have yet to completely remove. Had to grind off the head of the pin to take the trim off.
Users browsing this forum: No registered users and 48 guests
