Slot machine locks: Jennings, Mills, Pace, Jennings Club
Re: Slot machine locks: Jennings, Mills, Ace locks
Postby kentdun » Sat Feb 14, 2026 9:49 pm
I need 2 Jennings keys.
ODJ 342
ODJ 99
Can you check your stash?
Thank you
Kent
kentdun
Postby RameGoom » Sun Feb 15, 2026 7:47 am
Checked, don't have either one of those.
I should probably post the ones that I do have - maybe someone could match a number.
John
RameGoom
Postby RameGoom » Sun Feb 15, 2026 7:56 am
Here's what I have, original Yale/Jennings ODJ:
8, 16, 31, 37, 53, 57, 65, 87, 89, 93, 117,
134, 165, 171, 173, 179, 191, 193, 208,
210, 213, 258, 264, 268,
271, 310, 331, 350, 354, 357, 417, 435,
436, 437, 448, 449, 476, 483, 485, 490,
493, 499, 689, 695, 846, 858, 879, 919, 989,
1434, 1494, 1971
There might be a few missing from this list, but most of them should be in the stash I have. LMK if you have a match.
RameGoom
Postby 99623 » Sun Feb 15, 2026 12:45 pm
RameGoom wrote:I have a bunch of Yale ODJ Jennings keys. Also several DUO keys. Maybe a number match? Let me know what you need, I might have the exact number.
Holy S**t!
Thanks for the offer, I am set up to rekey the Yale locks rather quickly. Some that I encountered have been taken apart, missing pins, so I basically reload the locks with pins and get them back to being factory condition.
The DUO locks are the problem with so much variance, just like the mills locks, the different keys that are made are staggering.
Restored a 1934 Mills Castle Slot Machine.
Wasilla Locksmith Safe And Vault
Wasilla Alaska
907-315-0525
www.wasillalocksmith.com
Postby 99623 » Wed Feb 18, 2026 6:55 pm
I just got another shipment of slot machine locks. Each lock manufacture has it's own unique assembly.
Yale locks are a bugger to shim open with the spool pins. They are a six pin lock, which is unheard of today, and the keys are unique.
ACE locks, well they are held together with a pressed pin and if you don't drill the pin just right you are in a world of poop.
National pin tumbler locks are similar to the Yale.
Mills is not all that bad since I remembered a lot from my youth working on them. The most important thing is making scribe marks for disassembling each lock parts. If not you will be in a world of poop. The variation of Mills locks is another factor that can cause a hiccup also.
The real challenge is the DUO locks, that is the most difficult lock to make keys for with the opposing tumblers, The hidden wire ring holding everything together, it's a nightmare. I am still trying to re-engineer the lock assembly and my options are limited.
On with the show.
The good part is that the customer has sent me some locks that were damaged, this is a excellent source for parts, salvaging other locks.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Feb 21, 2026 4:24 pm
Well, it's been a interesting journey with these locks, I have got a lot of locks rekeyed.
The DUO is the only one that I can't do much with, they are extremely difficult to work on, I just fit a key to the locks. I had to make a fixture to take them apart and a cylinder set up fixture to assembly them.
These are the DUO locks.
These are the Jennings locks, and some other cabinet locks.
These are Jennings Club Chief ACE locks, Mills locks, and some of the cabinet locks.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Feb 21, 2026 4:26 pm
A lot of the locks are keyed alike, it's easier to keep everything constant, I have some key blanks coming in so duplicating them will be fast and easy.
This is one fixture to remove the cylinder. You can't remove the cylinder any other way, the lock mechanism is brittle, and will fall apart, I learned it the hard way.
The other photo is the assembly fixture.
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Feb 22, 2026 2:25 pm
I've gone as far as I can go, I am waiting for the Yale GB key blanks, I ran out of DUO used keys, with 3 DUO locks left.
Wasilla Alaska
907-315-0525
Postby flyingfred » Sun Feb 22, 2026 2:46 pm
Seeburg juke box remote stations use the same keyway as the Duo. Apprently the Seeburg version is a propritary item due to the really clean numbe stampings beginning with an "S". Both Duo and Seeburk locks were made by Illinois lock company as I recall. The Seeburg key is a work of art.
-Fred-
flyingfred
Postby 99623 » Sun Feb 22, 2026 7:06 pm
flyingfred wrote:Seeburg juke box remote stations use the same keyway as the Duo. Apprently the Seeburg version is a propritary item due to the really clean numbe stampings beginning with an "S". Both Duo and Seeburk locks were made by Illinois lock company as I recall. The Seeburg key is a work of art.
-Fred-
DUO is Illinois Lock Company, they have a lot of different locks not just DUO. DUO has been used in most of the coin industry. The wafers are really nasty to understand, you can't make a first fit key using a key blank, the wafers are specific to the original key, mated and a key blank will not fit. With the problem of having a lot of wafers, springs, it can get overwhelming.
Wasilla Alaska
907-315-0525
PreviousNext
