mills serial number list
anoyher mills serial number
Postby robtdix » Wed Oct 08, 2025 8:30 pm
having so much fun with the previous machine I've purchased another one.
Another Mills 5 cent which I'm guessing is of the 1950 vintage. Unfortunately, it has numbers at least six places. Is the number on the base of the mechanism the S/N?
And no this one does not work either.
robtdix
Re: mills serial number list
Postby radiorich123 » Thu Oct 09, 2025 5:42 am
The 206096 is the serial #. I had that machine worked good. The vendor part has problems with the castings.
bell-o-matic serial number list
Postby robtdix » Thu Oct 09, 2025 4:01 pm
any information on a bell-o-matic 10689 (that appears to be the sn)
robtdix
Postby MrDeeBee » Thu Nov 26, 2026 11:37 pm
I am working on a Mills Brown Front from around 1938. It has a torn label at the base. I believe I found part of the missing serial # that is a glued label. The very small piece has a four digit number stamped in ink and the paper color matches. Can someone post a pic of an original stick on paper Mills label with what a serial # should look like? There is a 3 digit number stamped on the base plate, left side. It is hand stamped and uneven. Could that be a serial # ? It also has a six digit # stamped in wood at the base where the center of the back door sits. I don't believe any of those 3 sets of #'s match. Everything seems to be all original though someone violently has been through the machine. All the signs were there. Boogered up heads, broken, sheared, and stripped threads of screws one most every part of the machine. I have returned the machine to playable with all parts working. There is wood glue split on the wood paneI at the pull handle side. I may take everything apart enough to get that fixed.
MrDeeBee
Postby nvmos2 » Fri Nov 27, 2026 6:58 pm
MrDeeBee;
The serial number on your brown front is the 6 digit number stamped into the wood.
Operators/distributors/locations often stamped their own identification numbers into their machines; your three digit numbers are examples of that.
Mills serial number sticker example attached.
Mills serial # sticker
