- IMG_6701.jpeg (73.17 KiB) Viewed 4624 times
Hi everyone,
I’m looking for some help with a Mad Money machine I recently picked up at auction.
I’ve carried out a few basic checks so far:
- IMG_6694.jpeg (81.7 KiB) Viewed 4624 times
I’ve manually tested the pull arm, and once I move the lock out of the way, all the reels spin and line back up correctly, which is great.
I’ve fitted a new power lead, and all the lights are working.
There is a slight hum coming from the internals, but nothing seems obviously wrong.
- IMG_6700.jpeg (74 KiB) Viewed 4624 times
The issue I’ve run into is when the door is closed and locked. When I insert a coin, it just falls straight through without registering, so I’m suspecting there might be something wrong with the coin gate or possibly a missing part.
I’ve attached a few photos — I’d really appreciate it if someone with more experience could take a look and let me know if there’s anything obvious that might be causing this.
- IMG_6695.jpeg (75.35 KiB) Viewed 4624 times
Any help or advice would be greatly appreciated!
Thanks in advance
