jennings prospector electrical question
Re: jennings prospector electrical question
Postby clubconsoles » Fri May 26, 2017 11:46 am
Hi Custer
I will try and help out I have uploaded the following from my Prospector, I am based in the UK.
https://www.youtube.com/watch?v=jX3XR6R ... e=youtu.be
https://www.youtube.com/watch?v=-nHIULQ ... e=youtu.be
hope this helps?
Nigel
clubconsoles
Postby custer » Sat May 27, 2017 12:20 am
wow.
thank you very much.
i go study this.
dou you know how the lights work?
is only the red light flashing when the arm is pulled?
are these parts available you think?
is the flashing bulb flashing from itself? or is something make the bulb flash?
i think is posseble that the part under the reels make the bulb flashing,could be a switch?
custer
Postby clubconsoles » Sat May 27, 2017 6:42 am
No problem.
Only the red light flashes and only while the clock is spinning as its the rod conected to the clock that pulls the wiper over those contacts.
I would say it would be difficult but not impossible to acquire these pieces as quite a few prospectors were produced.
clubconsoles
Postby custer » Wed May 31, 2017 11:06 am
thanks for your help.
i think i really miss too many parts if i see your movies.
i have only the naked mechanism too. your mechanism have many parts more extra on the mechanism than mine.
i think these parts are really difficult to find.
thank you very much! i go try to find the parts. but til now,... :cry:
custer
Postby clubconsoles » Mon Nov 29, 2021 2:49 pm
Custer, did you figure out your prospector in the end? I now have the Challenger monte carlo version and my red light flashes but never stays on. it is supposed to stay on every 4th pull, but doesn't. There is also a loose wire by the reed switches near the clock. can anyone advise?
clubconsoles
