Mills, a 1934 Castle slot machine, full restoration.
Re: Mills, a 1934 Castle slot machine, full restoration.
Postby 99623 » Sat Nov 08, 2025 4:47 pm
Parts came in today. Cover, blocker, shoulder bolt.
Restored a 1934 Mills Castle Slot Machine.
Wasilla Locksmith Safe And Vault
Wasilla Alaska
907-315-0525
www.wasillalocksmith.com
Postby 99623 » Sat Nov 08, 2025 4:49 pm
The payout card came in also.
Wasilla Alaska
907-315-0525
Postby 99623 » Sat Nov 08, 2025 7:11 pm
Found a back door, all authentic, 100% factory paint. :D
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Nov 09, 2025 4:01 pm
Today I have been working on the machine sitting in the cabinet, it was not fitting in the lower piece that it locks into. I have no idea how it happened, however it was like this when I bought it, after a few hours of adjusting it, it is perfect. No nuts, bolts, anything, was out of place.
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Nov 09, 2025 4:04 pm
I don't know how someone could have dreamed up this elevator, holy s*it it's a nightmare. I have worked on it for hours getting rid of the bugs, the wear and tear is compounding the problem. I am tempted to fabricate some way of adjusting some of the parts. Will see.
Wasilla Alaska
907-315-0525
Postby Bally Bill » Sun Nov 09, 2025 4:21 pm
making some nice strides in your restoration, it's nice to have the check detector on your machine but most have been removed to make the escalator cycle consistently. Did you cycle this on the bench before your installed it?
Bally Bill
Postby Bally Bill » Sun Nov 09, 2025 4:26 pm
[quote="99623"]Today I have been working on the machine sitting in the cabinet, it was not fitting in the lower piece that it locks into. I have no idea how it happened, however it was like this when I bought it, after a few hours of adjusting it, it is perfect. No nuts, bolts, anything, was out of place.
It also helps to have the hold down screws to keep reel mechanism in place (Right top and left underneath)
Mills Hold down bolt.jpg (52.53 KiB) Viewed 1156 times
Bally Bill
Postby 99623 » Sun Nov 09, 2025 5:06 pm
Bally Bill wrote:
99623 wrote:Today I have been working on the machine sitting in the cabinet, it was not fitting in the lower piece that it locks into. I have no idea how it happened, however it was like this when I bought it, after a few hours of adjusting it, it is perfect. No nuts, bolts, anything, was out of place.
Good idea. Thanks!
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Nov 09, 2025 5:10 pm
Bally Bill wrote:making some nice strides in your restoration, it's nice to have the check detector on your machine but most have been removed to make the escalator cycle consistently. Did you cycle this on the bench before your installed it?
I went and took it down, cleaned it up, sourced missing parts, the wear is a factor.
Wasilla Alaska
907-315-0525
Postby 99623 » Sun Nov 09, 2025 5:13 pm
Thanks everyone for your input, please keep them coming, I am grateful for everything.
David Walz
Wasilla Alaska
907-315-0525
PreviousNext
