Caille Slot Identification / parts wanted
Postby Bucky » Fri Jan 20, 2012 7:44 pm
Some pictures of my tentative fix for my missing hydraulic clock. I still have to make a lever arm to attach the damper to the existing arm. Then if all goes well, after adjusting the damping level, it should work as intended.
Damper mounting #3. Need to make a lever arm to attach damper to exisiting arm and I should be good to go.
Damper mounting #1
Bucky
Postby marsonion » Fri Jan 20, 2012 8:31 pm
Bucky wrote:PS do you have any pictures available (or can you take any) of the machine mechanics from the front and rear and sides, especially the lower end from the front and rear? Just trying to identify if I have any missing parts or springs.
I'll post pictures of the clock conversion mountings on my Commander when I get a chance. (I also have a clock on the remnant of the eBay Cadet mech I mentioned above, but that is sort of an orphaned novelty monster and I intend to build a see-through cabinet and other gizmos around it just for grins.) It looks like you're already a lot more advanced than that, though. I'd like to know more about the viscous damper you put in there; does it have a ratchet or valve or bicycle bearing for the CCW return stroke already built in? If so, it looks like it fits nicely-- where did you get it?
In making this substitution, you are fortunate that you have a post-Commander mech, because you'll notice that you have adjustable reel stop shoes which engage the operating fork, so you can time your "clicks" no matter how hinky the sendoff rates from your damper are during operation. That is, if it's too fast at the start and too slow at the end (for instance) you can compensate for that by adjusting those shoes. You wouldn't be able to do that with a Cadet, Dough-Boy or Dictator...
BTW I also noticed that those white-painted areas on the front casting of your machine could be where slots cut into the Knockout Deluxe "kick panels" showed white. Up to now I thought they just painted into grooves embossed into the chrome trim-- now it looks from the pictures like they were actually ventilated slots. I'd be interested to know if there is a white-painted area underneath the "mohawk" Commander/Cadet trim piece on top--?
Postby Bucky » Fri Jan 20, 2012 9:32 pm
The damper I found is a hydraulic rotary damper. There are different versions available, with damping in one direction (lh or rh ) or both directions equally. Also, there are versions where the damping is adjustable or fixed at a fixed level. My version is an adjustable one direction version, where the opposite direction is a non-adjustable minimal damping level. There is plenty of industry where I live, so it was just a matter of searching the web, and a 20 minute drive to pick up the in stock item. 8) more details once I actually get it working...
In regards to the paint, I will look at pulling off the top chrome to see if that is also creme underneath. It would make sense that this machine originally had the chrome trim with slots milled in to expose the creme color underneath. I don't believe this machine has been repainted.
Bucky
Postby marsonion » Fri Jan 20, 2012 9:50 pm
Bucky wrote:The damper I found is a hydraulic rotary damper. There are different versions available, with damping in one direction (lh or rh ) or both directions equally. Also, there are versions where the damping is adjustable or fixed at a fixed level. My version is an adjustable one direction version, where the opposite direction is a non-adjustable minimal damping level. There is plenty of industry where I live, so it was just a matter of searching the web, and a 20 minute drive to pick up the in stock item. 8) more details once I actually get it working...
I'll dust off my Grainger's catalog. Again.
If for any reason it doesn't work, clocks are available for ~$100.00 from the usual suspects. For mods to the crank arm, you're on your own, but doubt you'd have a big prob with that. At any rate, you'd likely get a more authentic feel of play from a hydraulic damper than a mechanical clock-- that's the "Silent Sphinx" effect.
Can't wait to hear about what's under the "mohawk."
Postby Bucky » Fri Jan 20, 2012 10:22 pm
Nope, not in grainger.
Acecontrols.com.
I don't know who the usual suspects are, as I am new to all this. But I will have less than 100 into the replacement. Minus my time, of course.
If the rivets come out easy, I'll have a pic of what's underneath the mohawk tomorrow.
Bucky
Postby Bucky » Fri Jan 20, 2012 10:27 pm
Acecontrols.com.
Bucky
Postby marsonion » Fri Jan 20, 2012 10:42 pm
Bucky wrote:
Acecontrols.com.
Thanks!
I think if you search up names such as "Berten" and "Krahl" along with terms such as "slot" and "parts" you just might hit on a few "clocks" for sale. Just saying.
Postby Bucky » Sat Jan 21, 2012 11:43 am
Well, the mohawk is off. No creme color paint. It was a pain too, as the forward "rivet" is really a hardened spiral pin, that I have yet to completely remove. Had to grind off the head of the pin to take the trim off.
No creme color paint under the "mohawk" trim. So who knows what this thing originally was.
There were 2 sets of holes at the rear of the casting. only one set was used to hold the trim in place
the remains of the hardened spiral pin, yet to be removed.
Bucky
Postby marsonion » Sat Jan 21, 2012 3:34 pm
Bucky wrote:Well, the mohawk is off. No creme color paint. It was a pain too, as the forward "rivet" is really a hardened spiral pin, that I have yet to completely remove. Had to grind off the head of the pin to take the trim off.
Well, that sure blows that theory! Sorry for your trouble, but I sure appreciate getting a look at this... even though I'm now even more doubtful as to how to distinguish a Play-Boy from a Knockout, etc.
I heard a story somewhere that toward the end of Caille's slot production career, the floor crews pretty much threw machines together from whatever parts they had on hand. That is, come 1939 or so, factory-fresh monsters built of combinations of old and new parts were turned out regularly just to fill the orders. Not sure if this is true or not, but it would serve to explain things like this.
BTW if your hydraulic damper arrangement works, you've got a customer right here!
Postby marsonion » Sun Jan 22, 2012 12:40 pm
Commander mech images below-- these ought to be similar to yours.
PreviousNext
