Getting a 1947 Mills Jewel Bell working again.
Re: Getting a 1947 Mills Jewel Bell working again.
Postby nvmos2 » Mon Jun 09, 2014 2:54 pm
keith;
I'm about 25 miles from you;
if you need to, you could bring your mechanism here and compare it to one of mine that is in good working order;
send a PM for contact info.
Jim
Postby keith23464 » Tue Jun 10, 2014 11:32 am
Jim,
I appreciate that. I think I have the mechanism working and I will be receiving what I hope are all the rest of my missing parts as well as the two manuals tomorrow. Hopefully I will be up and running shortly but I will certainly be in touch if I cannot get this functioning. I think my problems now might be isolated to the escalator. Also it appears that the box in the front center is a coin holder for overflow when the quarter tube fills up? If so I guess I cannot test the function of this part unless I get enough quarters into the machine to start filling it up?
This is what I am referring to, the part in the center:
keith23464
Postby nvmos2 » Tue Jun 10, 2014 12:11 pm
That box you refer to is your jackpot/reserve jackpot mechanism.
Yes; when the payout tube is full, coins flow down the chute into the jackpot.
When the jackpot is full, coins flow out the back of the jackpot down into the cash box.
When you get the literature, you'll see that you can easily check the operation of the jackpot without the mechanism in the case.
Postby TheFatman » Tue Jun 10, 2014 12:25 pm
Here are the levers that are responsible for tripping the Jackpot and resetting it.
Postby keith23464 » Wed Jun 11, 2014 2:38 pm
I received my manuals and some parts and have made some progress but I have a few additional questions. Hopefully everyone isn't tired of helping me yet! Here we go:
A. I replace the gasket on the slot lever pump and the pump "seems" to work correctly. But when I pull the handle down it does not go back up slowly as the manual says it should. It also says you can adjust it with the screw on the back but doesn't say how to adjust it. No matter how tightly I crank down the adjustment screw, air comes out of the small hole above the screw as in the picture below. I think the air escaping when you pull the slot handle down is keeping it from coming back up. Any suggestions on this one?
B. One of the schematics that I have shows a cover associated to the escalator as shown below: PN: MLB-8341. Is this a part of the escalator? If it is how does it attach? Do I need screws for it?
C. I received the springs to attach the two levers on the left of the excalator. I attached the spring for the inner arm to the post circled in yellow as instructed in one of the manuals. But I cannot find any reference on where to attach the spring for the outer arm circled in red. Does it attach to the same post that is circled in yellow? Lastly does anything attach to the hole at the end of the arm that is circled in purple?
Lastly the Owner's Pictorial Guide mentions a coin holding lever assembly on the back of the escalator in the area that i have circled in red below. As you can see I have nothing there, just two screw holes. But none of the parts lists or any other diagrams show this part so I do not know the PN for it or any screws or springs that might be needed with it. Is this something missing on my escalator?
Thanks again for any help that you can give me, I really appreciate it
keith23464
Postby watlingboy » Wed Jun 11, 2014 3:06 pm
Regarding the pump. You say the handle does not go back up slowly which would imply that it goes up fast but I'm guessing it stays down. With the screw in all the way, it should not return. Unscrew the screw until the handle goes back up and then fine tune it from there and then hold the screw in place with the nut. If it doesn't go up, do you have the correct handle spring?
That cover is held on by two 6/32 or 8/32 screws and it goes on the front of the escalator.
You are missing the second coin holding lever. Very commonly removed.
Postby TheFatman » Wed Jun 11, 2014 4:48 pm
[quote="keith23464"]I received my manuals and some parts and have made some progress but I have a few additional questions. Hopefully everyone isn't tired of helping me yet! Here we go:
Try covering that hole with your finger before you let the handle go. This should slow the handle down. The hole lets air back into the cylinder slowly, to retard the handles return to the top. If that happens, and the screw is all the way in, the screw might not be long enough to effect the air hole inside and it will need to be a longer screw. The adjustment is to loosen the nut, put the screw in all the way and a little bit at a time,1/2 turn , back the screw out until the handle returns slowly with the mech in the machine. The reason I think the handle is not slowing down is that the screw has probably been replaced with a short one, so the finger on it trick should show you if it is the problem. Otherwise, the gasket is not sealing well and air is leaking out past the piston and out the front where the arm goes in.
Dave F
Postby TheFatman » Wed Jun 11, 2014 5:02 pm
In answer to this question ..
I have both of those springs attached to the same hook and as far as the hole in the escalator advance lever, I dont have a hole in mine so I am not aware of anything going thru it.
Dave F
Postby keith23464 » Thu Jun 12, 2014 5:37 am
Regarding the pump and the slot handle issue. It sounds like I am being told that the slot handle should return to an upright position on it's own from the spring on the inside on the chassis and that the pump is just to slow down it's return? My slot handles does not go up at all on it's own. If I pull it down it stays down. The inner assembly for the slot lever all appears correct and the large spring for it seems to have plenty of tension but the handle stays at whatever position I leave it at. Any ideas on what I can try?
keith23464
Postby keith23464 » Thu Jun 12, 2014 8:18 am
I just realized that in all of my testing of the slot arm, the mechanism has not been installed in the chassis. Perhaps the mechanism also aids in pull the arm back up? I will test that today.
keith23464
PreviousNext
