I received my manuals and some parts and have made some progress but I have a few additional questions. Hopefully everyone isn't tired of helping me yet! Here we go:
A. I replace the gasket on the slot lever pump and the pump "seems" to work correctly. But when I pull the handle down it does not go back up slowly as the manual says it should. It also says you can adjust it with the screw on the back but doesn't say how to adjust it. No matter how tightly I crank down the adjustment screw, air comes out of the small hole above the screw as in the picture below. I think the air escaping when you pull the slot handle down is keeping it from coming back up. Any suggestions on this one?
B. One of the schematics that I have shows a cover associated to the escalator as shown below: PN: MLB-8341. Is this a part of the escalator? If it is how does it attach? Do I need screws for it?
C. I received the springs to attach the two levers on the left of the excalator. I attached the spring for the inner arm to the post circled in yellow as instructed in one of the manuals. But I cannot find any reference on where to attach the spring for the outer arm circled in red. Does it attach to the same post that is circled in yellow? Lastly does anything attach to the hole at the end of the arm that is circled in purple?
Lastly the Owner's Pictorial Guide mentions a coin holding lever assembly on the back of the escalator in the area that i have circled in red below. As you can see I have nothing there, just two screw holes. But none of the parts lists or any other diagrams show this part so I do not know the PN for it or any screws or springs that might be needed with it. Is this something missing on my escalator?
Thanks again for any help that you can give me, I really appreciate it
