There is also a larger broken spring. I see the same springs on the back of the mech, but can't see where it would be missing from. The spring is 2 1/2" long (total):
bakerb95619 wrote:Hello Dave, thanks very much, the pin was to hold the payout fingers at the back. That explains why every pull was paying out 18 coins, winning combination or not.
I had to find a small nut and lockwasher for the pin, but I got it all back together and all payouts work correctly now including the token vendor for BAR-BAR-BAR.
Thanks again,
