Mills HiTop Reel Assembly Removal
Postby MoreBloodWine » Sat Nov 20, 2010 5:46 pm
I need to remove the reel assembly form my machine to replace a missing piece thats being blocked by it. So, can anyone tell me preferrably with pictures how to remove the reel assembly from my Hi-Top ?
Get your own sig @ myu2sig.com - Total unique user count: Image
MoreBloodWine
Mills Reel bundle removal
Postby watlingboy » Sat Nov 20, 2010 9:01 pm
Cycle the mechanism and stop the clock fan immediately. Leave a screw driver or something in the fan so it can't complete the cycle. Unhook the 3 springs that go to the reel stop levers. Remove the reel brakes if it still has them. Unscrew the 2 screws at each end of the rod that runs through the reel bundle. Some rods are screwed in and some are just pushed in. If there is a slot at the end of the rod, unscrew it. While holding the reel bundle on top of the center reel, pull out the rod going through the reel bundle. While still holding the bundle, lift up and at the same time pull the reel stop levers forward and out of the reel bundle. Reverse the process to put it back in. You can leave the clock in the stopped position until you put the bundle back in or if not, cycle the mechanism and stop the clock again when ready to put it back. Sorry, no pictures but it should be pretty easy.
Postby MoreBloodWine » Sat Nov 20, 2010 9:25 pm
Sounds good and reel breaks ?
Just so I know if I need to replace em or not.
MoreBloodWine
Mills Reel Bundle removal
Postby watlingboy » Sat Nov 20, 2010 11:52 pm
Reel breaks are the wires which are held on by a screw and a wing nut and ride on the hub of each reel. These allow you to slow down the reels, by tightening the wing nuts to put more pressure on the hub, so the reels stop arms are not beating the bundle to death. The reels should almost come to a stop before the reel stop arm comes down and finally stops the reel. These are frequently missing on a lot of mechanisms but easy to find to replace.
Postby MoreBloodWine » Sun Nov 21, 2010 12:42 am
If it's what I have in mind then I believe I am missing them, thse would generaly be found in a vertical position on the back of the mech right ?
Plus I don't recall seeing any wind nuts on my mech.
Looks like I need to get more than I originally anticipated.
Edit: Pic would still help just to be sure...
MoreBloodWine
Postby MoreBloodWine » Mon Nov 22, 2010 7:27 pm
Ok, so I got the reels off ok and got the piece put on that I wanted, but in doing so I think I got some dirt in somewhere because now the one reel spins a little slow. In any case, I plan on getting the thing fully cleaned at some point so I wont worry to much about that right now. I also confirmed what the reel breaks are and that I do not have them but luckily I found a set on eBay for $12 shipped.
MILLS SLOT MACHINE MECK BRAKES ( ORIGINAL ) LQQK
In any case, I'm not even sure how they really go on there so I'll probably hold on to them til I get the mech cleaned etc and just have the "restorer" put em on along with nay other pieces I may need but ya, looks like I'm good to go for right now so thx.
MoreBloodWine
Postby Dave » Sat Nov 27, 2010 1:19 pm
You can go to http://www.ibuyoldslots.com/dvd/ and watch the video on the reel bundle. This is a short YouTube video which contains excerpts from the restoration DVD set that I sell. The excerpt does discuss the brakes.
Postby MoreBloodWine » Sat Nov 27, 2010 3:40 pm
Dave wrote:You can go to http://www.ibuyoldslots.com/dvd/ and watch the video on the reel bundle. This is a short YouTube video which contains excerpts from the restoration DVD set that I sell. The excerpt does discuss the brakes.
I know why you only have excerpts in there but it cuts out on I'm guessing whats sort of important. It rides on the... "switch to something new".
Thx for that though, I'll go back and watch it again later.
MoreBloodWine
Users browsing this forum: No registered users and 35 guests
