hello,
am new to the forum.
just bought a number of machines, a number of models i have
never had before so some questions if anyone can help with info
that would be great.
right,
the jennings prospector is only the cabinet and castings, eg
no mechanism and it has been removed from a console of
some type. i am aware that it had a larger jackpot with the
two additional coin displays either side of standard jackpot,
[grub stakes?] anyway, there was a e/m flashing light above
the standard jackpot, which was only lit part of the time. If you
hit the jackpot without the light visible you only won the standard
jackpot, ie the jackpot attached to front of the mechanism. however
if the red light was showing when the jackpot was hit, then you won
the standard jackpot plus.......well i thought both side pots dropped
into a drawer underneath, which was opened by an e/m switch linked
to the redlight.
now finally to my question....i know its took a longtime to get here...
on my cabinet as you look at it, there is a hole cut out below the glass
panel to the left of the jackpot to presumably drop the extra jackpot
window....BUT there is no corresponding hole cut in the cabinet base on
the right hand side?
did the prospector only payout x1 extra window and not both or is my
cabinet different for some reason?
