not a cadet
not a cadet
Postby marsonion » Wed Dec 18, 2024 11:21 am
eBay item number:335732395444
ANTIQUE 1936 CAILLE 5 CENT CADET BELL SLOT MACHINE W/LOCK & KEY CASH BOX
I believe the seller might be a member of this forum; just want to inform him that the machine in the pictures is actually a 1935 Caille Doughboy, not a 1936 Cadet... and there might be just a little more money in a Doughboy than a Cadet.
Re: not a cadet
Postby wallruss001 » Wed Dec 18, 2024 1:39 pm
I don't know if I can stay away from that one, just an hour and a half up the road. My two Cadet's are nickel, wish it was a different denom.
wallruss001
Re: not a cadet
Postby just frank slots » Wed Dec 18, 2024 3:20 pm
True Not a Cadet! I was just on EBAY I have one just like it that's green... Interesting machine I must say. Mine was a parts machine that someone put back together and sold to me... Eather, it had missing, broken, wrong parts or who knows what else. Test it first and be sure everything is still there if nothing else. Offer him $200.00 less I think he might take it... If you do buy it show pictures of the mechanism...
just frank slots
Re: not a cadet
Postby JoJoCopper » Wed Dec 18, 2024 3:37 pm
Uggh....those hydraulic pumps. There used to be a guy that rebuilt them and would do a swap when you sent yours in. I had a Play-Boy that we did a swap on may years ago. is anyone still working on them these days?
JoJoCopper
Re: not a cadet
Postby wallruss001 » Wed Dec 18, 2024 4:24 pm
Cory and Squires in CA did have rebuilt regulators and would swap for $300.00 with your old one. I've cleaned and repacked the needle valve where it leaked with thread, like old steam valves. I used high quality brake fluid for refill.
wallruss001
Re: not a cadet
Postby memphisbigdave » Thu Dec 19, 2024 5:47 am
I rebuilt my Caille Commander timing pump. Not a lot of information out there. Crack it open and clean it really well. Take the case and shaft to Ace hardware and find a seal for the shaft and gasket for the top. Take the needle valve out and fill it with brake fluid. Put as much as you can in, and reinstall the pump. I had to lay mine on the side and add more brake fluid. Works great
memphisbigdave
Return to E-Bay
