It is already up to $10.50
http://www.ebay.com/itm/231199747921
Whosignedmeup wrote:Dave,
You and other members of the 'COPS' are very quick to SLAM slot machines that are not correct. I find it funny that on your own listing http://www.ebay.com/itm/231199747921, you fail to SLAM your own machine. As a COP, shouldn’t you be held to a high standard? Why don't you mention how the machine was incorrectly restored in the wrong colors? The whole COPS thing is a JOKE!
If the machine is restored but the colors are not the same as factory original should I disclose this?
You can if you want but there is really no need to do so. In many cases, people who restore machines have taken great liberty with the paint scheme. The most common example is the Rol-A-Top Bird of Paradise. Since the paint scheme is obvious and not hidden there is really no need to point it out. Of course, there is no harm in doing so either. Of course, if you advertise the machine as restored back to factory original then the paint scheme and colors should match the factory colors as close as possible. Unless you have the exact color formula it is impossible to match the color 100%.
I forgot to mention that the machine DOES have the following parts (commonly missing on the reproductions)
1. Horizontal check detection lever
2. Vertical check detection lever
3. Vertical finger lockout hardware which engages when a trade check is used
4. Handle pump
5. Back door and back door lock. Reproductions rarely have original back doors and locks since these are expensive and original back door are somewhat hard to find.
The serial number on this machine is 410731 and this machine are registered in the Coin Op Registry (CoinOpRegistry)
In addition, if you look at the photos you will see it has the correct handle for a five cent Castle Front.
The machine also pays on two cherries (not one like the vast majority of the reproduction machines do).
I indicated the machine has been restored. Like almost all restored slot machines the paper reel strips and paper award card are replacements.
Also, the cash box is a replacement. Very common since the cash box is the first thing stolen back in the day.
Someone asked if the machine were restored to factory original colors.
The answer is no. The paint scheme that was used is a very popular one that people who restore Castle Fronts use. It is not uncommon for different paint schemes to be used when restoring machines. A very popular book called "Slots on Parade" shows many examples of machines that were painted differently than the way the came from the factory.
It would not be difficult to repaint the machine to factory original colors if one so desired. The Castle Front is one of the easier machines to paint. Personally, I don't think doing so would increase the value though.
Go to AntiqueSlotMachinePriceGuide site and do a search on Castle Front to see what the factory original colors would be.
CoinOpBuyer wrote:Well, this is interesting. I looked up a profile on eBay for "whosignedmeup"
"whosignedmeup" has been a member since 2002 but only involved in three transactions.
The last one was with "TheBentCoin"
Hmmmmmmm
