Jennings pull question
Re: Jennings pull question
Postby pj waelti » Sun Feb 15, 2015 5:50 am
Well maybe I have it the best it can get. It definetly is about the same as my skyscraper or maybe a little harder. but definetly harder than my bursting cherry.
pj waelti
Postby mechanic » Sun Feb 15, 2015 2:21 pm
Check the main spring attached to the main operating lever(pork chop) the spring should be no more than 3/8" away from the peg when the pork chop is all the way up. You have to take the spring off the top peg to check the gap. If it is more than 3/8" it causes excess tension on the pull down lever and handle.
Postby pj waelti » Sat Mar 07, 2015 10:12 am
Thanks for all your help, sometimes there are things the books can't help you with.. PJ
pj waelti
