Thoughts on 5/2/15 VCA / Morphy auction
Re: Thoughts on 5/2/15 VCA / Morphy auction
Postby Frank » Fri May 08, 2015 10:50 am
I saw the Jennings Witch and it was convincing. It was about SN 100,040 - I have a for sure genuine one and it is SN 100,017 - I believe they may be easily authenticated by SN which should be 100,000 to 100,020??
Frank
Postby Dave » Fri May 08, 2015 1:25 pm
My original witch is 100,056. I have been told that they only made 500 witches and the valid serials are 100000 - 100499.
I am looking at my serial report list today and see that the Witch in the auction had a serial of 100040. If that is correct then it could have very well been a real witch and the person stole it because it was not advertised correctly.
I sure wish I would have seen it at the auction to have a close look at it.
Postby terick2104 » Sat May 09, 2015 4:22 am
In Richard Bueschels Illustrated Slots Volume 3. Serial numbers for the witch are between 100,024 and 100,546.
terick2104
Postby terick2104 » Sat May 09, 2015 4:48 am
Correction - He has four Jennings Witches listed with serial numbers between 100,024 and 100,546, I didn't mean to imply those numbers are the lowest and highest numbers of the Witch production run.
terick2104
Postby DeTrana » Sat May 09, 2015 5:58 am
My witch is definitely guine and is 100,017. Could Jennings have been making Victoria model b during the same run? :D
DeTrana
Postby watlingboy » Sat May 09, 2015 7:15 am
I can't tell you what Jennings did but I do know what Watling did. Watling numbered their machines consecutively as they were built. For example, you can have a Bird of Paradise Rol-A-Tor with a serial in the 67 thousand range. You can also have a Bird of Paradise in the 90 thousand range. My guess is, Jennings did the same thing. And I'm sure they made the Model B at the same time as the Witch. One thing the manufacturers wanted was to make as many different models as possible while using as many parts as possible that interchanged between models. They didn't set aside a group of numbers that were used for a specific model and neither did they build one model all at once, numbering them consecutively. So I think it will be very hard to separate the rubber Witches from the real ones through serial numbers.
Postby Anglobritish » Sat May 09, 2015 8:11 am
Hi,
When you talk serial numbers, there are so many models, also some manufacturers produce machines (Even today) and start with perhaps 1000,001 and so forth, I know from actual reports at the time of production that Mills Novelty Company advertised that in the first 8 months of 1928 they produced more than 125,000 of their O.K. Front Vendor model, that calculated, comes to just over 15,500 per month, also several of the larger distributors advertised used models for sale with numbers around 60-70,000, these numbers are in the actual adds in the trade magazines of the period. Although some collectors like to compare the numbers on their machines to get a more exact date of manufacture, I think if you can get close to the year of production that is good enough for any collectible, unless it is of course in the single digits.
I have a Bally Fleet pinball game, this machine is number 93 and was made in July 1934, it as the serial number on the cabinet, on the front door and on the key, when I researched it, I found in a trade paper dated 1936 a comment from Ray Moloney President of Bally, where he stated that "Our new machine is in production, and we will be producing it in even greater numbers than when we were producing the Bally Fleet at a rate of 700 per day" .
Freddy
Anglobritish
Postby terick2104 » Sat May 09, 2015 8:33 am
The Model 'B' replaced the Witch, so it is very possible that their serial #'s overlapped. There is a Model 'B' vender front listed in Bueschels book 3 with a serial # 100,573 and three others in the 100,000 range - 100,710 - 100,857 - and 100,997.
terick2104
Postby Frank » Sat May 09, 2015 8:58 am
If serial numbers can't be used to ID Witches, how else can you spot a fake?
Frank
Postby Dave » Sat May 09, 2015 6:45 pm
Regarding my earlier post about the juice being 20% for Internet and phone bids.
I have since found out that the juice is 20% of phone, Internet, and live.
However, for all three cases, if you pay by check or case you get a 2% discount.
I thought the 2% discount only applied to live bidding but it does apply to phone and Internet.
Sorry for any confusion.
PreviousNext
