GOLDEN NUGGET JENNINGS SLOT??
Re: GOLDEN NUGGET JENNINGS SLOT??
Postby MONTI » Wed Sep 09, 2015 8:54 am
SLOT DYNASTY wrote:OK Gentlemen, I got my callback from the person that I mentioned above, that I was sure would know all about
the Jennings "Golden Nugget" machines in question.
I will try and be as brief as possible, and will start with the machine pix in this thread, from the top.
Photo1: This late chrome Jennings, is as I thought it was. A TOTAL FAKE. Was also informed, that he was sure
it is one of the Vegas Butchers creations, as he was known to slap these together.
Photo2: Is definitely a Hans FAKE. The case and coin tray are not correct. He knew that Hans had been putting
these together for quite some time.
Photo3: This is a REAL Mills HalfTop "Golden Nugget". Everything is correct, and it is totally original. As you
can see, it does not look anything like the 99.9% of all the FAKESTERS on eBay, and elsewhere.
Photo4: This Jennings "Chief - Golden Nugget", is also the 'Real Deal'. It has the correct chrome wrap-around
coin tray. These models were on location in the Casino, and were on floor stands. So, the machine will
have a hole in the base panel, for the overflow to fill the large canister or bag in the base. All of these
models also had a hand-load jackpot, but the mech. had to be slid out to fill it. Unlike the key-operated
front-load on the Mills. I was also told, that some of these models had a dollar bill acceptor, attached to
the upper left side, next to the reel window, when on location. Now, when will one of those show up? It
must look very interesting. But I'll bet that the Casino removed those, before they left the premises.
But any of those machines will have an opening in the side panel, or at least extra bolt-holes.
So there you have it. Some real honest-to-goodness, good news for a change. =D>
Thank you Bill,
Knew you would have a definitive answer as usual! :D
So the answer to my question is that they did use Jennings slot machine in the Golden Nugget, the Jennings Chief model!
Probably not as many in count as the Mills Half-tops that were used as on Alan's site under antiques he does make mention to about 200 Mills Half-tops originally used.
Since there were not as many Jennings Chiefs used they are probably "Very Scarce", don't want to say "Rare", that word is over used, and being "Very Scarce" are probably all in the hands of avid collectors, while the Half-tops, being more in quantity were copied profusely in the market as you mentioned!
The production time of the Mills Half-tops and the Jennings Chief from the factories, in my opinion, match the usage of the slot machines in the casino also!
The production time of the Jennings Sun Chiefs would have been slightly later!
Kudos to you Bill and thanks for your input.
On our next phone chat I will ask you who your source is!
Take Care My Friend,
Ciao,
Postby Rockola » Thu Sep 10, 2015 10:16 am
Hi I have been going through my archive and came up with this one, picture watermark dated oct06.
The slot has the wear you would expect for an original GN.
Is it real no dolls.
Pete
Rockola
Postby SLOT DYNASTY » Thu Sep 10, 2015 10:54 am
Rockola wrote:Hi I have been going through my archive and came up with this one, picture watermark dated oct06.
Pete
Even though the machine in your pix appears to be an original Jennings example, with the correct coin tray, there is
a feature that does not seem correct. I was also told by my contact, that all the factory models, had the arrow pattern
on either side of the jackpot, filled-in, and the dolls mounted. So either they didn't do some, or this one is not factory.
Postby Swami » Thu Sep 10, 2015 11:22 am
The Picture Rockola posted is an ORIGINAL Golden Nugget. In Fact, I know that exact machine and the owner. It is 100% original and NEVER restored or tampered with. The Golden Nugget Ran Jennings Standard Chief's and Prospectors. The Standard Chief's were all painted Gold on Top and Blue on the bottom. NO DOLLS on the Standard Chief's. If you see one with Dolls they were added after they left the Casino.
Swami
Postby MONTI » Thu Sep 10, 2015 11:30 am
Pete
Well, now I am really confused but sometimes that doesn't take much to bring about!
At least, that's what my wife says!
Bill, I must ask that since the number 4 picture does not have the Arrows filled in how does that fit into the mix?
Not that I can say either way as I am just the responsible party for bringing this question up, right?
It really does seem there are a lot of these puppies out there from many different sources!
Postby Rockola » Thu Sep 10, 2015 12:24 pm
Hi i found these from 2003 Gn with Bill acceptor
Pete
Rockola
Postby Anglobritish » Fri Sep 11, 2015 9:21 am
Hi Guy's,
You all seem to be having such fun with this Golden Nugget Mystery, well I thought I would join in the fun, I have attached several pages from my article titled The History of Slot Machines In Nevada, here is a section on the Golden Nugget machines, you will note that the Blue and Gold Jennings Golden Nugget is pained inside, that would never have happened at the factory, also the inside label would also have details of any "Special" requirements for the customer, this as none. I am also attaching a picture of a Buckley Golden Nugget, this could possibly be a Mills Black Cherry revamp.
I think the last picture from Monti says it all, this I am sure is the only true Golden Nugget machine that could have been supplied to the Golden Nugget Casino direct from the factory. You have to remember in the late 1940's, the casino's did not install a vast number of slot machines, when the ultra modern Desert Inn, first opened in the 1940's, they had more machines than any other casino, 75 machines in total, so the market was not that great for the manufacturer or the Distributor.
Has for bill validators being installed in these models, that would have been impossible as bill validators were not introduced to the gaming industry until the mid 1990's, that that introduction according to the Nevada State University was deemed the 9th, advancement to slot machines since there inception.
Keep it coming, it is good for the collectors.
Freddy Bailey
Anglobritish
Postby MONTI » Fri Sep 11, 2015 3:11 pm
Anglobritish wrote:Hi Guy's,
Freddy Bailey
Thank you for your input Freddy,
Documented material and written information is always good and you seem to have a hand on this type of information!
I did just return your email on this as I was in Reno/Sparks this morning picking up slot machines to work on so sorry I got back to you late.
Little did I know when I asked this question that this thread would take off like it did but I truly look forward to all the comments as our hobby is nothing without the research that goes into it.
As Freddy said "Keep it coming!"
