Caille Slot Identification / parts wanted
Postby marsonion » Sun Jan 22, 2012 12:48 pm
Commander mechanical clock conversion:
Postby Bucky » Sun Jan 22, 2012 3:22 pm
Cool! Thanks for the pictures. If you don't mind, I may (er will) have requests for future pictures.
As far as my rotary damper conversion, it isn't going so well at the moment. I have it hooked up, but I think there are a few problems at the moment. 1) I think the damping level is too high, even on it's lowest setting. The reels stop before they are supposed to mechanically (when/if they spin) and 5-10 seconds later the thing goes kachunk. 2) The first reel sometimes doesn't spin, because I think the damper has some slop before it engages on the return stroke. So when the arm the damper is attached to changes directions, it moves maybe a 1/2 inch before the damping kicks in. I'll post pics in a bit of what I have. But the parts a "developement" parts and not what I would have once/if it gets working properly.
I am sure there are various other issues I have to deal with.(reels not lining up, bent linkages, things binding up in the payout mechanism, generally out of adjustment and just beat on etc etc.) The first thing is to verify by comparing pictures that you provided to what I have have and just make sure I have all the parts/springs etc.
So with that, I am going to take a short break and chill. I have a booklet coming that hopefully will describe the operation of this machine, and all the different systems, how they work, and how they interact with each other. That alone should help me get this thing going. But until I understand it, it will be tough to keep going.
Bucky
Postby marsonion » Sun Jan 22, 2012 6:14 pm
The problem with your damper sounds familiar to me. My first effort at a mechanical clock conversion used a "Space Manufacturing" clock from a '60s slot which featured a bicycle bearing instead of a ratchet for the return stroke. That resulted in about 15-20 degrees of slop at the start of the cycle which is enough to cause the first reel stop to smack down after only 2-3 symbols had squeaked by and to turn the escalator into a nickel catapult. (This is also what happens when a pump has leaked too much hydraulic fluid, BTW.) The cycle begins with a great deal of torque on the pump so it has to be very tight at that reversal point.
If the literature you're getting is the Coin Slot Guide #3, I'm afraid it's so Superior-intensive that you might not find it all that useful for dealing with the post-1933 models. I'd say there's about a 60% coverage of the sort of problems you can expect with the Fuller-Johnson contraptions; almost everything above the escalator is different, for instance, and that can be a very temperamental area.
For comic relief, here's a picture I saved in my WTF file: the upper casting is from a Commander, the front is from a Cadet, and it has a green reel window and lever, but all the rest is coated with red crinkle-paint. I sorta doubt they came off of the Detroit factory floor this way:
http://www.icollector.com/images/271/20 ... 8_1_lg.jpg
Postby Bucky » Sun Jan 29, 2012 10:58 am
Well, it's been a few days, but things are working a little better. I have revised the angle that the arm mounts to the damper, and that has helped a lot. I can actually use the machine, and the reels spin and work (sort of).
Now that things sort of work, I can see what else is really needed. The reality is that the whole machine needs to be completely torn down, cleaned, and reassembled, making all the appropriate adjustments and tweeking as required. Lack of use and time collecting dust/dirt/grime has taken its toll. The payouts generally don't work, as things are binding up in the payout mechanism. The reels don't spin evenly, and the symbols don't line up as they should. All minor details compared to getting the damper installed and working.
I am still having issues with the damper moving a distance before actually damping things. But I know how to fix it by revising my linkage angles again. basically just need to have the arm on the damper pointed at the mechanism, (about 1 o'clock when ready to spring) so that for the initial travel, the rotary motion is a lot more compared to the linear motion of the mechanism.
I have short video clips (8-10 seconds) showing the operation of my machine, so if you have an email, (marsonion) I will send it to you. Or anyone else for that matter. Or maybe I will sign up to youtube and post it there.
underneath view of the rotary damper installed. Not much space, and not ideal from a kinematic standpoint.
crude but effective linkages. Once working as it should, new pretty links will be made.
Bucky
Postby marsonion » Mon Jan 30, 2012 11:18 am
Bucky wrote:I have short video clips (8-10 seconds) showing the operation of my machine, so if you have an email, (marsonion) I will send it to you. Or anyone else for that matter. Or maybe I will sign up to youtube and post it there.
You have a PM--
Postby Bucky » Tue Jan 31, 2012 1:47 am
You have a PM--
Check your email...
Bucky
Re: Caille Slot Identification / parts wanted
Postby mechanic » Wed Dec 16, 2015 4:47 pm
I ran across this posting while doing research on some Caille stuff. I see that there was posted 2 different pics of the Caille Playboy Model. It seem that the first pic is of a Commander with a Playboy decal on the reel window and the handle is for a Commander. The second pic show a different machine with a Playboy decal which I think if I can remember correctly is the correct model and even has the right handle. Can I get some of the membership to verify if I am correct or just completely confused.
Postby marsonion » Wed Dec 16, 2015 5:35 pm
mechanic wrote:I ran across this posting while doing research on some Caille stuff. I see that there was posted 2 different pics of the Caille Playboy Model. It seem that the first pic is of a Commander with a Playboy decal on the reel window and the handle is for a Commander. The second pic show a different machine with a Playboy decal which I think if I can remember correctly is the correct model and even has the right handle. Can I get some of the membership to verify if I am correct or just completely confused.
Welcome to the Land of the Confused. =D>
I've been trying to find reliable sources of information regarding these very questions for years. All I can turn up are conflicting accounts and freakish images of machines that simply don't fit the narrative. My default position at this point-- to which I allude somewhere on this thread-- is that these so-called Commanders, Playboys, Knockout Deluxes, etc. and any ensuing monster-models emerged from a period of great distress for the Caille Bros. Co. in their final years (1938-39) of slots production, during which the floor crews jerry-built them in any way they could, using whatever parts or material they could turn up, just to get them out the door to fill the orders. I heard that story from an old guy... and I've seen machines "trimmed" with what appears to be gutter flashing. Really.
If you find any primary, authoritative sources which would serve to set all of this straight in some neat and purty way, please share them here. I have machines in my collection and don't know what to call them!
#-o
Postby mechanic » Wed Dec 16, 2015 6:42 pm
#-o
I do know Caille Bros would sell their prototype machines after they finished their tests on them. Most parts were hand made. This is why you may find 5-7 variations of some models like the Center pulls, nude fronts and early superiors. The one I have not heard of though is the Knockout Deluxe. It could be under a different name here, like many other machines. I do have some parts on E-bay at present and a lot more not listed.
Postby marsonion » Thu Dec 17, 2015 11:44 am
All I "know" about the Knockout model line appears on pg. 157 of Bueschel's "Lemons, Cherries and Bell-Fruit-Gum." I have run across no other sources whatsoever... except I have seen (and own/owned) machines that sort-of fit the sidebar description or ad image, but are as often as not explicitly labeled as Playboys on a reel window sticker.
PreviousNext
